Probe context menu "favorites"/defaults?
Greetings, this may seem like a basic question, but I cannot find any details. Is there any way to set the default control used for a probe, or create a favorites/most used list? 99% of the time I probe an array, I want a graph, not the numeric array. As it stands, I have to go through quite a few menues to get there. See the attached picture. I played around with creating a custom control briefly, but to do this for every data type seems absurd.
(2,305 Views)
I guess you have to create a new probe (Custom probe>New...).
I think you'll have to do that for each data type.
IIRC, it will be default (when you select "Probe") when it's the last probe you selected
(2,289 Views)
