Probe tool grayed out in TCP examples
as I'm currently playing around with the "TCP communicator - Active.vi" examples I noticed, that there is no probe function available. Is this normal behaviour?
\Ulli.
(4,435 Views)
Accepted by topic author Ulli27
Individual VIs can be set to diable debugging (File->VI Properties->Execution). By disabling debugging, memory is conserved and performance improves slightly.
The TCP libraries from NI are considered tested and should not require debugging. They VI you are looking at may have this flag set to improve performance.
(4,417 Views)
Ok. that was simple, but very helpful.
Thank you.
(4,414 Views)
