Probing an IMAQ image constant inside a cluster produces a 'Failed to load or create probe' error in LabView 2023 Q3.
When trying to probe a cluster with an IMAQ image constant, a 'Failed to load or create probe' error pops up. Even if the cluster contains other elements.
The below cluster is being probed.
Doing the same thing in LabView 2021 produces no errors and the data is visible in the probe.
I don't want to probe the image constant but rather, I want to probe the other elements inside the cluster.
I have attached the VI used to demonstrate the issue.
Message 1 of 1
(977 Views)
