Problème de graphe (temps relatif) - acquisition de données en temps réel.
Maybe i didnt understand what you said james, but i don't want to loose the time data :s. Just display a correct relative time.
Message Edité par Madje55 le 03-25-2010 08:12 AM
Message 11 of 14
(890 Views)
My misunderstanding Madje,
Try this. I haven't tested it, but you should get the idea.
You can change the data that you put in the queue and change the waveform properties.
The display should not slow down your "data get" here.
James
(Saved for 8.2)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 12 of 14
(880 Views)
Thanks James, but... I still have the problem. Plus i don't really understand what you have done.
Maybe i wasn't clear enough in my explanations. Here's a picture, showing my problem.
Message 13 of 14
(878 Views)
My mistake, I sent you a broken VI.
Here is a working one which should do the job for you.
Look at the templates to see what is going on.
File>New>From Template
James
Message 14 of 14
(855 Views)
