Problem -10452 and 1 other!?!?!
Whenever i try to output a continous analog signal on a channel, i get error code -10452,
Error -10452 occured at AO Control
POssible reasons:
NI-DAQ LV: No interrupt level is available for use
This even happens when i use the testing procedure to output a contrinous signal. Last time i asked this question,they told me to reinstall the driver and look at the common problems. I did that and there are NO conflicts between the NI-DAQ and anything else. I am lost. I personally think its because i didnt specify an IRQ interrupt for the NI-DAQ, because i dont see it listed anywhere for it. What could this problem be???? I am also getting really mixed up problems when output a DC voltage, the value is way off, and w
hen i read it in, the value doesnt read in until i input 10 V on it, but it reads it as 1 V. Help please
(2,586 Views)
What device are you using to output the signal? Some boards (example: the 6703 & 6704) are DC output only and cannot generate waveforms. Are you using a standard example to test this? Does the board pass "Test Resources" and Test Panels in MAX (Measurement and Automation Explorer) or NI-DAQ configuration utility?
(2,586 Views)
