Problem Active-X Container and MSAgent 2.0
Property nodes connected to an Active-X container contain customized info when I drop most Active-X controls into front panel container, but I am trying to use MS Agent 2.0 control to do voice output, and when I drop this control into Active-X container, the property nodes remain empty as if the control was being ignored.
(2,926 Views)
The MSAgent control will not work in LabVIEW 6.0.x on Win2000 or WinNT. This is a known issue and our developers are working to resolve the problem.
The agent works on Win9x/ME systems and as an automation server on Win2000 and WinNT.
I apologize for any inconvenience this has caused you.
Marcus Monroe
Application Engineer
(2,926 Views)
