Problem Addressing 6031E DAQ
I have a 6031E DAQ board installed my system. When I have tried to address
a channel over 8 on the board, the VIs give me an error. Is there a special
VI that someone has used to address over 8 channels?
Thank You,
Kurt Zdanio
Ovonyx, Inc.
(2,805 Views)
I think you may have it set up to be in differential mode. If that is true,
channels 0 and 8 make one differential channel, 1 and 9 make one channel, .
.. . , and the whole think starts over at 16 & 24, 32 & 40, and finally 48 &
56.
If you need more channels, change the configuration to single ended.
I hope that this helps,
Bob Young
"Kurt Zdanio" wrote in message
news:39241dad@newsgroups.ni.com...
address
special
> Thank You,
> Kurt Zdanio
> Ovonyx, Inc.
(2,805 Views)
