Problem Aligning and Processing Measured Data with a Fixed Reference Vector in LabVIEW
I’m working on a LabVIEW program where I have a fixed reference vector containing 15 expected values. The measurement arrays I’m processing contain rows with fewer than 15 values, which are often incomplete or misaligned.
My goal is to reconstruct each row so that it contains exactly 15 values aligned with the reference vector. For each value in the reference vector, if a measured value within a tolerance of ±3 is found, I keep it; otherwise, I insert a 0 at that position.
I’m having trouble implementing this logic in LabVIEW, especially with array traversal and conditional insertion. I’m attaching my current LabVIEW program and would greatly appreciate any ideas or solutions to solve this problem.
For example, given this reference vector (always 15 values):
[3, 3.99, 14, 18, 22.66, 30, 34, 39, 44, 49, 55, 61, 67, 76, 80]
and a detected measurement row (only 13 values):
[3, 9, 19, 35, 39, 43, 45, 49, 63, 69, 73, 80, 84]
the expected corrected output is:
[3, 0, 0, 19, 0, 0, 35, 39, 43, 49, 0, 63, 69, 73, 80].
(1,264 Views)
Are the values in each vector (sic) (or row) guaranteed to be sorted?
Shouldn't the output be a 2D array with N corrected rows?
(1,239 Views)
Accepted by topic author elbazi05
I have no idea if this is what you want, but maybe it can give you some general ideas.
(1,223 Views)
Thank you for your feedback, it helped me a lot
(1,190 Views)
