Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Problem: Array data from a COM object works fine at first call, but it crashes at following calls
ibslk
Member
02-05-2002
04:45 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
If I retrieve array data from a COM object using the variant_to_data.vi it works fine at the first call, but at following calls there are no data or LabVIEW hangs or chrashes.
I'm using LV 6.0.2. Is there anybody how has an idea?
0
Kudos
Message
1
of 1
(2,413 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
