Problem Configuring Web server silverlight
When I select Tools>>Options>>Web Server... then click "Configure Web Server". The resulting page say I do not have Silverlight Installed on my computer. However when I follow the link to install SilverLight the Silverlight installer complains and says that I already have Silverlight 64-bit installed. How do I configure my web server? Can I not use Silverlight 64-bit?
Craig
(4,030 Views)
This is a guess, but if you are running 32 bit LabVIEW in a 64 bit machine you may need the 32 bit version of Silver light -- like with java if you have 32 bit browser on a 64 bit computer.
Mike ..
Certified LabVIEW Architect
LabVIEW Champion
(4,009 Views)
Accepted by topic author craige
Good point. I figured it out. I was using Chrome and when Chrome redirected me to the download page the web browser didn't recognize that I was running a 64-bit system. Regardless, when I used IE everything worked fine. Thanks for the follow up!
(4,000 Views)
