Problem: Differential mode, measures 1.4 V, USB 6009
Hi everyone
I'm measuring charging and discharging two capacitors, individually.
I'm using the USB 6009;
Two capacitors, two graphs, two analog inputs (AI0 +, AI01 -) and (Al1 +, Ai1 -);
I configuredin differential mode; ok
Problem:
When a capacitor is switched off, it measures 1.4 V
Message 1 of 9
(3,688 Views)
Do you have a schematic of your circuit?  What is happening when you turn the switch off?
GCentral
Message 2 of 9
(3,674 Views)
Hi, Sorry my english is not very good..
R:   USB 6009  Analog Input Reads Approximately 1.4 ,
Thank you
Message 3 of 9
(3,660 Views)
Let me rephrase that.  What does your circuit do when you turn the switch off?  Is the capacitor left there with nothing connected?  Do you connect something to drain the charge on the capacitor?
SHOW US YOUR CIRCUIT'S SCHEMATIC.
GCentral
Message 4 of 9
(3,646 Views)
Thanks for your help!!  croossrulz
R: The capacitor discharges, 0V.
R: Resistor  1M
Message 5 of 9
(3,636 Views)
Message 6 of 9
(3,634 Views)
Sorry!!
R: The capacitor discharges, and Usb 6009 Analog Input Reads Approximately 1.4V ..... I want to 0V..
Thank you
Message 7 of 9
(3,614 Views)
Accepted by topic author Saille
Try setting up the task correctly-  Use the DAQ Wizard to create the TaskSmiley Wink
Dev1/ao0  would be much better-  Oh, and now that you have the Wizard open-  Do look at the wiring diagram it provides you withSmiley Very Happy
For 6009 DIFFERENTIAL mode task AI0 is + AI3 is - and you only reserve explicitly reserve AI0 (The AI3 line is reserved by seleting the + line in the channel and declairing that it is differential)
And give the Task/Channel a meaningful name  "MyCap1Discharge" would be helpful.......
Now let's speak about your electrical engineering:
The input impedance of the 6009 is 144kOhms  The 1MOhm discharge resistor becomes moot as soon as you connect the monitoring 6009 AI.
Message 8 of 9
(3,608 Views)
Thank you Jeff Bohrer
Thank you Crossrulz
Sorry my english is not good
well, the circuit worked, I removed the1M resistor and put 10k
Saile
Message 9 of 9
(3,585 Views)
