Problem Please open the Vi named popup
Hello
I have a problem opening a certain vi
when I open a vi lets say "Main.vi" labview popsup a "Please select the vi named: Main.vi"
this is a little strange for me. normaly you gets this message if a certain subvi or control cannot be findt in the location.
Normaly you can sellect the Vi mentioned but than I still cannot open the Main.vi
Ignore Vi also doesn't work the main.vi is not opened
I cannot open the Main.vi to look what was going wrong
Does someone have a sollution or surgestion to this problem
a day bevore I was doing some software changes in the Main.vi. But I don't know what I have done wrong.
greetings
Robert Nijhof (Silverbullet15)
(2,979 Views)
Can you attach your main.vi?
(2,969 Views)
I will try to attach the Main.vi (I was looking for some extra info with google and it seems that NI knows this problem but do not have sollution
found message regarding my problem on
http://www.codecomments.com/archive273-2004-8-250624.html
Code is a litlle big ( I must reprogram it)
(2,968 Views)
Hi Robert,
I could not open your attached VI, LabVIEW says it is not a VI. Could you try and zip is and then attach it?
usually when a VI asks for it's self this means the VI has been corrupted and LabVIEW can't make sense of it.
Karsten
(2,937 Views)
