Problem Reading FP AI-110 with FP-1600
I get an old FP-1600  and some moduls, I am trying to test the Module AI-110, but wen I try to run teh .vi, I get this error: "SubVI 'FP Read (Float Array-IO).vi': subVI is missing.
Could you help me with this error?
(3,127 Views)
Hi Francisco!
My first question would be what version of LabVIEW and of the FieldPoint driver are you using?
The error you are getting seems like an incorrect installation error, hence why the VI seems to be missing. The following link, shows some relevant information about this:
http://digital.ni.com/public.nsf/websearch/7B21ADB6CD5ADCDF86256A3B0052D2A0?OpenDocument
If you need to knwo whats the best version of the FieldPoint driver for your version of LabVIEW let me know and ill find out for you.
Hope this info helps.
Have a great day!!
(3,105 Views)
Thanks Oswald
I was Using version LabView 7.1, and FielPoin 4.1, but I have to install Field Point Explorer Version 3.0, in ordther to can configure the IP of the FP-1600, after I Install the Fiel Point Explorer the Error apears.
I really apreciate if you could recomed the best version of Field Point.
Reagards
(3,097 Views)
Hi Francisco!
I would suggest updating to Field Point 5.0, here is the link to get it:
http://digital.ni.com/softlib.nsf/websearch/C17B06F91F539183862570D6007EA79D
Also its a good idea to update your firmware version on the FP 1600, i was able to find a link for version 5.02, you can upgrade in MAX, right click on the controller and select firmware:
http://joule.ni.com/nidu/cds/view/p/id/910/lang/es
If there was an issue with the driver, this should solve it. In case it doesnt, we need to check some other things.
Let me know how it goes!!
Have a great day!
(3,085 Views)
