Problem Stop VI for acquisition
Hi.
I've got some problems in stop a VI for the acquisition from cRIO.
I see that if i don't push the botton acquisizione (with which i want to decide when start the acquisition) i can exit from the VI clicking on the button chiudi acquisizione but if i start the acquisition and then i stop it with the botton stop acquisizione and then i want to stop the VI (with the chiudi acquisizione) it doesn't do nothing. It is as though it remained checked-out and doesn't quit the VI.
can you show me a way to solve this problem?
i don't know how to solve this problem Smiley Sad
(3,731 Views)
you have to be sure that the chiudi applicazione controll is readed after the case structure ( in order to verify this, highlight execution of VI). It seems like chiudi applicazione is readed at the start of first while loop. If so you can use a sequence structure.
Let me know if this solve.
Clara
(3,707 Views)
Hi clara tnx for the reply. (are you italian?)
In any case your project is in lab8.2 and i have lab 8.0 could you make a jpeg of the change you have done?
tnx again per your advice.
(3,700 Views)
(3,689 Views)
Hi.
i've tried your solution but it doesn't work. I mean it acquire the signal as always and if i stop the acquisition it stop s but if i click on Chiudi Acquisizione it doesn't exit from the VI as before.Smiley Sad
(3,668 Views)
