Problem Stopping the VI
Hi.
After I ran my VI, I found that some of parameters/outputs only showing their values when I "Quit" the TDMS File.
Instead of that, I would like the VI to stop by it self without clicking any button but it doesn't.
Anybody have any suggestion how to fix this problem?
Thanks.
Firdaus
p/s : Please refer attachment for the VI.
(3,255 Views)
ok
I hope this help it is a simple example of a while loop terminating after 15 iterations if you want to slow down the interations all you have to do is put a time function.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,247 Views)
ok here we go:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,246 Views)
Well, if you don't want the TDMS Viewer and it's dialog to close it, don't call it in your code.
(3,241 Views)
Harold Timmis,
Thanks for you sugesstion. But I think that the easiest way to AutoStop it. But it doesnt match or suitable for my VI.
Dennis,
Thanks for your idea. I think its gonna be worked with it.
Firdaus
(3,237 Views)
And if you do want to use the TDMS viewer, put it in a separate loop so that main will not pause when it's open.
(3,231 Views)
Dennis,
I decided to not put the TDMS Viewer in the code.
Thanks.
Firdaus
(3,227 Views)
