Problem Transferring TDMS file from cRIO 9076 to Local PC using Labview code
Dear All
I am using LabVIEW 2013 with cRIO 9076 for datalogging TDMS .
I try to tranfer the logging file(.tdms) cRIO to Computer via LabVIEW FTP program. The transferring is OK but from computer i can not open the file error -68007.
It is ok when i  copy the file from cRIO to computer ( ftp://192.168.2.102 and manually copy the file)
How can i solve  ploblem and does LabVIEW FTP  allow us to trnasfer file.tdms?
Thanks and Regards
Luong.Tran
(2,975 Views)
Accepted by topic author Luong.Tran
(2,953 Views)
