Problem Whit Solution
Hello, I developed this software to create a test You can choose two types of operation , complete or NO test. The part of the complete test is working properly , check all the entrances to the outputs and prints a file the report ... The problem is that I do not know how to do instead the part where it stops when it finds an error , after the error message , the operator must press OK and double-check the same program , will not advance until the control is not ok . I don't understend, The FOR is AutoIndex whit Array and I find the error Number (4,9,14) but I wuold repeat the test to error 4
Sending the program , the test file ( TestFile.txt ) and the report file ( Report.txt )
Message 1 of 8
(5,477 Views)
sorry that i am not able to understand your problem.
i can tell onething that the existing code needs to be changed completely.
Use state machine architecture
For Reference
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(5,453 Views)
Ok I search to explein the problem...
I have a Case Structure with True or False
Now True or False work equal....
But i search for False Case when I have a Error  Re-Test this and not increment the (i) on loop for
I have implemented this
Message 3 of 8
(5,446 Views)
THANKS For Explaning.
If My understanding is correct you dont need to increment when false/Error Encounters.
If so add shift register with and increment only if your value is true/ No error.
But then you need to re frame your architecture, you can go through the link for basics of state machine architecture
shared in earlier post
Message 4 of 8
(5,440 Views)
You answeare is Perfect.. but I don't can use the Shift Register weil I use a Indixing FOR, and this is the difficulty... I think a solution is use While Loop whit Exit condition when the Error is False, and Continued when is True.. But is not a elegant solution..
What do you think?
Message 5 of 8
(5,437 Views)
Same post repeated twice pls ignore
Message 6 of 8
(5,432 Views)
Accepted by topic author andreabello
Are you aware of LabVIEW Design Patterns
"State Machine Architecture" Try to use you that your problem will be solved.
Message 7 of 8
(5,431 Views)
THX is all ok
Bye
Message 8 of 8
(5,396 Views)
