Problem With CINTOOL
i am using Code Interface Node to write a program in C
After compiling the code VC++ ,generated the .lsb file
and added the generated .lsb to Code Interface Node in LabVIEW
when i try to run it is showing still i have to add in the broken arrow error messages
(2,781 Views)
The CIN is obsolete and no longer supported. Why are you trying to use it instead of a dll and the call library function node?
(2,775 Views)
