Problem accessing float data through MODBUS
Dear All,
                 I am taking the data through the MODBUS in LabVIEW, but this time the data are floating point containing four bytes and having the decimal values, but the problem is values after decimal are truncated and it indicator doesn't shows it? so what could be the problem? is it  a problem of MODBUS with float data or it is a problem of LabVIEW indicators? what changes are required by me to show  the correct data?
Hope for the positive reply.
Thanks in advance,
Nishant
(3,465 Views)
hi there
please post some code
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,463 Views)
Modbus only lets you read/write 16 bit register values. It is up to the labview program to convert the values into flating point. see this thread.
(3,459 Views)
Hi there,
If you are reading floating type data, the appropriate conversion is required to get single value from four bytes.
Hope this would help.
(3,448 Views)
Dear Mr. Unclebump,
                            Thanks for the info., it has immidiately solve my problem , thank you very much, so kind of you.
Nishant
(3,443 Views)
