Problem acquisition between pc and omega A10
Hi
I'm using an indigo omega A10 camera and when i'm using MAX all do i get is a binary picture.
It means when i grab a 16-bit picture from the cam there is a high state and a low state  ( 7350 for a hot surface and 7260 for a low one ) and I should have at least a dynamic range because i'm using the 16-bit mode of the camera.
I downloaded the indigo driver from ni site and i'm currently using it. Does someone have any clues ?
Thanks.
Romain (FRA)
(2,442 Views)
Hi
I just need some complementatry information:
Which board are you using ? Which driver version ?
and finally can you send me a picture ?
Alexandre D
(2,434 Views)
