Problem at deployment of shared variables
Today I installed Labview 2010 at a pc that already had Labview 8.5 installed. After the installation was completed I tried to run a vi that includes shared variables with both Labview 2010 and 8.5 and both times at the deployment of the shared variables this error occured :
(error:-2147220735, (Hex 0x80040301) Internal error:
The specified class could not be found in the configuration
database. Your installation may need to be repaired.)
I have restarted the computer many times, I tried to reinstall labview 2010, i also recreated the shared variables in the project but i still get the same error. What coud be the problem?
Thank you very much
(3,517 Views)
Hi panagiov,
looks like your installation is broken. Please follow the instructions on "Clean Reinstall Procedure.pdf" I attached. Let me know if you need any further assistance.
(3,489 Views)
Thank you very much
(3,479 Views)
I had this exact same error caused the same way.  LV 8.5 is installed and I installed LV 2010.  It actually worked for a few hours then I started getting this error.  Works fine when I deploy the same project from another computer.
(3,344 Views)
Hi Nick,
did you try to reinstall LabVIEW 8.5. If you really need 8.5 you should try it. Otherwise you could just leave 2010 installed and repair that installation.It seems that there is a problem with the installation, so it is necesary to deinstall and reinstall 8.5 at least. Please try that.
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(3,307 Views)
