Problem controlling instrument
I am working on a project to make measurement using B2900A and Agilent E5250A. Right now I have a  problem to control Agilent E5250A using its driver. Does anybody knows how to specify the channel list to the open and close vi's?
(3,125 Views)
You should show your VI, preferably a snippet (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US ), so people can have a look. Usually these drivers come with some simple example VIs, did you try one of these? These examples show you how to use the driver VIs, like the Open and Close functions. It is not clear without more info what you mean about "channel list".
What is the interface/protocol you use? RS232? RS485? GPIB? Ethernet?...
(3,088 Views)
