Problem converting U8 array to date-time string
Hi All,
How can I convert U8 array (time_t data type from C dll) to date time string?
A dll function that I am calling has a structure of string, integer and time_t as one of the parameters. Instead of passing cluster, I pass an array of U8 of the size that the structure should be. All the members of the strcuture and parsed correctly except the date/time.
Function Parameter:
typedef struct {
Int AlarmState ;
Int AlarmGrade ;
TCHAR AlarmMessage [100] ;
time_t AlarmTimeStamp ;
} WV_ALARM_INFO ;
Total size = 4 + 4 + 100 + 4 = 112
Using Call Library Function, I set the parameter type to Array of U8 and size 112.
After the array is populated when the function is called, I have done the following to interpret date and time.
1) Using Extract Zero Terminated String.VI I converted U8 array (of size 4) to string.
2) Type casted string to integer (I32).
3) Swap bytes
4) Swap Words
5) Format Date/Time String.
Please see the attached screenshot for visual display of the above.
Ideas on why the year is incorrect?
Mimansa
(3,109 Views)
Hi Mimansa,
Is it only the year that is incorrect? Also, where did you find that ABC\0 VI that you use 3 times? Did you make it or is it in a labview library somewhere?
Laura
(3,081 Views)
