Problem cycling through elements of an array using a for loop ~ error 200609?
I'm outputting a 194-element array from a MATLAB script node into a for loop where the array is indexed then converted into a 8-bit boolean pattern which I'm trying to output using DAQ Assistant. I'm using LabVIEW 8.2 and a PCI 6133 DAQ using a counter(Ctr0InternalOutput) to time the output. The first element of the array goes through the loop perfectly however never makes it's way back through and throws error 200609: Generation cannot be started because the slescted buffer size is too small. Increase the buffer size. After probing the line before DAQ Assistant I confirmed only one element makes it through the loop and then throws this error? I've trying doing the same things with lower lowel DAQmx vi's using a DAQmx configure output buffer vi to override this buffer size problem, but still get the same result(not the error but same data flow problem)? Anybody know what's going on? I've included the vi's I've been working with. Thanks!
Millie
Message 1 of 1
(2,789 Views)
