Problem detecting device through RS232 port on sbRIO 9631
I'm having trouble detecting a Hokuyo URG-04LX laser rangefinder connected to a sbRIO 9631 through the rs232 serial port. I can confirm that the rangefinder works through the computer, and is detected by both MAX and VISA when connected through the serial port on my computer. I have the following software downloaded on the board:
LabVIEW Real-Time 9.0
Language Support for LabVIEW RT 1.0.0.3
Network Variable Engine 1.6.0
NI-RIO 3.2.1
NI-VISA 4.5.1
NI-VISA Server 4.5.1
Variable Client Support for LabVIEW RT 1.6.0
In NI MAX, all I see under "Devices and Interfaces" in the configuration tree is the RIO0.
TIA
(3,134 Views)
Accepted by topic author oswong
Hi oswong,
If you install "NI-Serial RT" on your sbRIO-9631, then it will enable support for the onboard RS232 port on your Single-Board RIO.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(3,106 Views)
