Problem displaying array
Accepted by topic author ceilingwalker
Add a Delete From Array function right before the array is written to the indicator "Array". You'll be leaving the Row input empty and wire values for Column (start index) and Length. It looks like you also may need to remove the first column because it's just the Serial Number? This would require you to just include an Array Subset node as well.
Cheers
Message 11 of 13
(1,818 Views)
I will try it. Thank you for your patience.
Message 12 of 13
(1,806 Views)
Thank you Sir, it worked perfectly. Smiley Happy
Message 13 of 13
(1,774 Views)
