Problem displaying correct x-axis/y-axis data
please see attached picture..
Message 11 of 17
(3,050 Views)
Hi max,
please show also the "raw" data before plotting them in the graph!
I get this when running my version of your VI:
Message 12 of 17
(3,046 Views)
here..
thanks for your help!
Message 13 of 17
(3,041 Views)
Accepted by topic author s.steen
Hi max,
easy solution: when you don't want to have horizontal lines in your XY graph you should not use the same X value more than once in your data!
Prove: sort the X array and display it in an indicator. You will notice, that several X values occur more than once in your X data!
See this:
Message 14 of 17
(3,036 Views)
Oh ..double x values.. 😞 ??
Thank you so much for your help! I will have to look for the reason for these double values..
Message 15 of 17
(3,023 Views)
Hi sarah / max,
why do you change your username that often?
Or did I encounter a forum bug? There were replies from user "maximillian00100"…
Message 16 of 17
(3,013 Views)
I changed it today from Sarahf. to Sarahsteen. I also wondered who "Max"is..
Message 17 of 17
(3,009 Views)
