Problem during connecting the oscilloscope
Hi Im writing a program for measring a signal from Tektronix TDS3054B oscilloscope
Message 1 of 14
(4,641 Views)
Hi Im writing a program for measring a signal from Tektronix TDS3054B oscilloscope but during the running of the program it got an I/O error at the GPIB-read component. do you have any good suggestion for this problem. the picture of the secound sequence is athached
Message 2 of 14
(4,637 Views)
If you are asking for help, I suggest the following:
    1. The error you are getting
    2. Version of Labview and OS
    3. GPIB card if NI or not
    4. Condition when the error occurred
    5. The VI itself instead of the picture.
Message 3 of 14
(4,631 Views)
I would recommend you use the driver instead of your code. Definitely dump the sequence structure and use VISA functions instead of the low level GPIB.
Message 4 of 14
(4,612 Views)
this is just a little part of the program Im trying to write. but the error is occurring here.
Im using Labview 2010 and windows vista enterprise.
the error is  :   Error 6 occurred at GPIB Read in test1.vi
Message 5 of 14
(4,609 Views)
You are aborting the 'AUTOS EXEC' it seems. Like I said, use the driver instead of trying to reinvent the wheel.
Message 6 of 14
(4,605 Views)
sorry Im new in Labview . what do you meen with driver?
Message 7 of 14
(4,598 Views)
Accepted by topic author parsa
The Instrument Driver Network has links that explain what a LabVIEW driver is and how to use one. Then go to the earlier link I gave you and download the appropriate driver. I would recomend the project-style driver.
Message 8 of 14
(4,593 Views)
thanks
Message 9 of 14
(4,585 Views)
Hi again
I have tried the VISA functions but I steal have the same problem. I can communicate with the Oscillator and send commands but not reading from it. I attach my new program.
the error is as following: Error -1073807339 occurred at VISA Read in test2.vi
Message 10 of 14
(4,562 Views)
