Problem executing Mathscript code fopen
Hi All,
I am using the function fopen in Labview mathscript.
I am using it as
fid=fopen('calfile.cal','wb');
w is for write mode and b is for IEEE floating point with big endian byte ordering.
However, when I execute it I get an error
Error in function fopen at line 41.  The input parameters are not in the required format.
Kindly help.
Thanks in advance
(3,176 Views)
Hi Venke, the parameter that is not identified is the b. File open is the reference for the file, more than the information on the file itself. In the next link you can see a description of the valid parameters for the parameter:
http://zone.ni.com/reference/en-XX/help/371361B-01/lvtextmath/msfunc_fopen/
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,162 Views)
