Problem from "Read from Spreadsheet file.vi"
dear all,
I run into some problems from "Read from Spreadsheet file.vi".
I have a waveform file which has 4437 rows and 10 columns, representing 10 channel waveform.
Use "Read from spreadsheet file.vi" , I can only output one column waveform.  I don't understand why I can not get a 2-D array with 10 row & 4437 columns from the file.
How can I get all columns of waveform? Anybody can tell me? The files are attached
It is a Labview 7.1 file, Thank you very  much!
(3,582 Views)
Hi hbin,
      Try setting the  ReadFromSS "delimiter" input to space ("\s") instead of the default (Tab). Smiley Wink
Cheers
Message Edited by Dynamik on 03-12-2006 06:22 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
(3,572 Views)
Hi, DynamiK,
 It still does not work after I input a string constant with "\s",
I still only got one row from the file after transpose.
Am I have type erros with "\s"?
(3,565 Views)
Hii,
      I think here is wat u want as u, wrote that u want ten different channels in the ten different graph, so always give the selection to the column, instead of row, bcos, that shows the channel. I am attaching the file here. have a look at it and if anything else, get back to me.
Nishant
(3,552 Views)
Hi, Nishant. Your modified vi still does not work, there are nothing out in Waveform chart 2 & 3
Thanks anyway
(3,551 Views)
Hi hbin
You don't have to use "\s" as delimiter but just a space. Wire either a stringconstant and just enter a space or wire a space-constant (new in LV8.0).
In addition to that, you should use a waveform graph - not a chart, as these two types of display are not for the same purpose.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,548 Views)
Becktho, your way works:), thank you very much!
Also thanks any of your guys answering me, giving me suggestions:).
Sometimes I feel the help file from LabView  is not detailed enough that I can not  understand :(.
(3,541 Views)
