Problem getting USB interrupt data after reopening device
Hi there,
I am working on a LabVIEW 8.5 program to read some A/D values from an instrument we built.  The instrument has a Microchip PIC18F4550 microcontroller in it, and the USB firmware supplied by Microchip configures the chip with an Interrupt OUT and an Interrupt IN endpoint.  I'm using NI-VISA 4.2 for communication, and the PC OS is Windows XP Pro.
I used NI VISA Driver Development Wizard to create a USB RAW driver, and my device shows up under MAX just as it should.  After I got my device configured, I wrote a simple VI that waits for the user to enter a device command and push a button, and after the button is pushed the VI waits for a response.  The command is sent via Interrupt OUT transfer, and the response is via Interrupt IN.
The problem I have is that I can't run my VI more than once.  If I run it once I can send a command to and get a response back from the device, but if I re-run the VI it times out waiting for an interrupt event from the device.  I can get the VI to work one more time by unplugging my device from USB and plugging it back in again, but that's obviously not a good way to handle things.
My question is, am I handling all of the VISA I/O correctly?  As far as I can tell I have, but maybe I need another set of eyes.  Attached is my VI.
Mike
(3,018 Views)
Sorry, I think I posted this on the wrong board.
I'll post it on Instrument Control (GPIB, Serial, VISA, IVI).
Mike
(2,989 Views)
