Problem getting VI to display 2 analogue inputs continuously
Can anyone help me with the following VI, I can not get it to continuously display the analogue inputs only one starts each time the VI is started? I am creating a front panel where the scaling can be altered for calibration purposes.
(2,377 Views)
You are creating two task for the channels in the same card i guess that is giving you the issue. Create a single task and run the code.
(2,370 Views)
