Problem in Block Diagram Editing
Hello Friends,
I have problem in editing Block diagram of my Main VI. Whenever I try to move any object or wire on my Block diagram the whole block diagram moves (momentarily) with it and same happens when I place that object/wire at final position. This problem makes editing slow and also spacing between other objects in block diagram is also disturbed.
Please find below link of Video of the problem :-
https://youtu.be/asz84Wg6_n8
Please let me know the solution of this problem.
Message 1 of 19
(6,334 Views)
Hi ssingh,
how big is your block diagram?
Mind to attach your VI?
Message 2 of 19
(6,299 Views)
@GerdW wrote:
Hi ssingh,
Dear GerdW,
Thanks for your reply.  Yes the block diagram is quite large. But I would like to inform I had reduced the size 2-3 months back (VI size came down from 4.8 mb to nearly 3 mb) and that it was working very well previously also at that huge size. Attaching VI may not be possible due to office policy.
Message 3 of 19
(6,293 Views)
HI ssingh,
I'm talking about the dimensions in pixels. You find those values using the "VI Metrics" in the Tools->Profile menu.
3 MB is still quite large…
You know LabVIEW will compile your VI in the background with every change you do. Did you change the compiler settings in the last time (Tools->Options->Environment)? What happens when you change that setting to other values? (Read the help as mentioned next to that compiler setting slider!)
Can you create an example VI demonstrating the very same problem?
Message 4 of 19
(6,291 Views)
All Block Diagrams should fit on a single Screen.  A better "Style Rule" is All Block Diagrams should fit on a single Laptop Screen (or 1024x768 pixels, or some other "small" rule).
The key to accomplishing this can be summarized by one word:  SubVIs.
Reference:  Peter Blume's "The LabVIEW Style Book".
Bob Schor
P.S. -- I wonder if you haven't accidentally "selected" the entire Block Diagram, which means moving something moves everything ...
Message 5 of 19
(6,270 Views)
I wonder if it has to do with the fancy "real time" block diagram update feature in later versions of LV (2015 +)?  I know this, combined with large block diagrams, can bring your PC to its knees when moving objects, causing all kinds of weirdness.  I forget what the option is, and how to disable it; hopefully this post jogs someone's memory.
Bill
CLD
(Mid-Level minion.)
Message 6 of 19
(6,255 Views)
Looking at the scrollbars, it does not seem that the block diagram is way oversized, but maybe the origin is way off center. I would try to do a "select all" on the diagram, copy it and paste it into a new VI to see if it makes a difference.
Here is a link explaining the limits for the coordinates..
Message 7 of 19
(6,245 Views)
Dear GredW,
Thanks for your reply. Please find below my In-Line reply in orange color :-
@GerdW wrote:
HI ssingh,
 I am attaching an image for VI Metric, size in pixels seems to be 4750 X 2360.
Yes I did tweaked that setting but it had no effect.
All other VIs are working fine, however they are not so large.
Message 8 of 19
(6,220 Views)
Dear Bill,
Thanks for your rely. I too suspect that this feature (or some thing similar related to Block-Diagram UI Update) causes this problem.
Can someone Kindly shed more light on this.
Message 9 of 19
(6,217 Views)
Dear Altenbach,
Thanks for your reply. I could not exactly understand your words "origin is way off center".
Did you meant to say that some stray block diagram object may be lying far away that the rest of the Block Diagram's center? I checked on that and center seems to be ok to me.
Message 10 of 19
(6,214 Views)
