Problem in Control and Simulation
I was working in control and simulation module of NI Labview 2013 and created a VI as shown in the attached file but i do'nt understand the output of the VI.
I applied a unit step input to Transfer function = 1/(s+1), and the desired output (exp(-t)) is shown in green colour (Drawn by me in MSPaint) but it displays the output as the one shown in red colour.
As the inverse Laplace of 1/(s+1) = exp(-t), the graph should be having a value of 0.3678 at t = 1 and 0 value at t --> infinity but the output (red) is exactly opposite.
Some one can please explain the output that why is it like this??
Regards
(3,705 Views)
Accepted by topic author Waqar123
When applying a step response, you have to multiply your transfer function by 1/s to account for the step input before performing the Laplace Transform to obtain the correct result. In your case, the transform yields: (1 - e^(-t))
There are lots of explanations of step responses online, but here's one.
(3,671 Views)
