Problem in Data Range of Control
Hi
Iam using two controls A and B. I want different minimum and maximum range for them. e.g  0 to 100 for A and 100 to 1000 for B.
 I set range of A by right clicking and select data entry from property it set the range, but when i want to set range for B it has automatically saved range of A.
Similarly when i try to set range of B it effects range of B.
May be iam forgetting some thing.
Thanx in advance.
regards
mazhar
(4,274 Views)
Hi mazhar,
it should be no probem to use a different range for both controls. Do you try to set it in an array? It's not possible inside an array.
Mike
(4,269 Views)
What kind of controls are they? It would be great if you could post the VI with controls that exhibit this issue and let us know what version of LabVIEW you are using.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,266 Views)
No i am not using Array please check the attached VI
iam using LabView 8.6.1
thnx for your time and intrest
(4,261 Views)
You've run into this bug.
(4,247 Views)
Accepted by topic author mazhar.ali
thanx Dennis
 the following link gives the patch which fix the bug.
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1276
regards
mazhar
(4,224 Views)
