Problem in Executing Command Line
Hello all,
   I am trying to execute the Perforce command lines through LabVIEW System Exec. These commands are working propery when directly entered in the command prompt, but through LabVIEW it is not working properly.
"P4 client -i  <E:\template.txt"
This command will read the file and create a client. Whenever we are doing this kind of  file operation (reading or writing), the command through LabVIEW is not working and the System Exec VI is giving the Standartd error output as  " Usage: client -i [ -f ] Unexpected arguments", but working perfectly in the comand prompt,
(4,185 Views)
hi cranen,
  use "cmd/c P4 client -i  <E:\template.txt" as command line input to the system exec.vi.
Thanks and regards,
srikrishnaNF
Srikrishna
(4,180 Views)
System Exec.vi is throwing an Error, the command is not valid.
(4,169 Views)
Hi cranen,
  You need to wire the path of the concerned executable file also..
Thanks and regards,
srikrishnaNF
Srikrishna
(4,166 Views)
