Problem in Loading an image onto a .NET Picture box in a standalone LabVIEW application
Hi All, I am using an .NET picture box control in my FP which allows me to resize image without much fuss. The snippet that loads the image is attached. I build an application for the same and when I run it, the attached error pops up. How does a code that works in development environment throws an error in the standalone application. Am I missing something here? any help in this regard is appreciated. Thanks in advance Regards, S.P.Prasaanth
(3,086 Views)
It's a common mistake generally happens when using Path.
-Try creating indicator at path in both environments and see what is the difference.
-And read: http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363
Edit: Attach actual code/vi instead of screenshot to get more help
uday
(3,059 Views)
Hi Uday,
Thank you for the response. But I am sure the file path is correct. I have verified the same as well
Regards.
S.P.Prasaanth
(3,055 Views)
