Problem in Sound and Vibration toolkit Installation
I have Sound and Vibration 3.1 installed in my machine and did upgrade (without unistall SV 3.1) to SV 4. VIs doing in other machine with SV 4 don't run in my machine. I try uninstall version 3.1 and stay only version 4, don't solve problem. The SV version 4 don't appear in function windows, but is installed in windows XP. Sound and Vibration section in the function windows only appear if i install version 3.
How do upgrade of version 3.1 to version 4 and do the version 4 section appear in the window function?
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
(3,628 Views)
If you have multiple versions of LabVIEW installed, or another LabVIEW directory, say LabVIEW 6 or 7, make sure that you install into the correct LabVIEW directory, example LabVIEW 8.2.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,623 Views)
This is a common problem with toolkits.  I always uninstall the old before installing the new.
Make sure that both versions are completely uninstalled and then install the new version again.
(3,623 Views)
I have sure that installed in correct version of Labview (7.1 in my case)...the problem is that when put SV version 3.1 CD Installation..i have uninstall option, but with version 4 CD installation, I don't have this option.
Other tip for me?
Thx for all
(3,617 Views)
Try the Add/Remove Software option from the Windows control panel.
(3,615 Views)
Solution for WinXP:
1 - Enter in Configuration - Control Panel - Add/Remove Program;
2 - Select National Instruments Software, click in Change;
3 - In the new windows that opened, remove the Sound and Vibration toolkit 3.1 version and 4.0 version;
4 - Restart Computer
5 - Reinstall Sound and Vibration Toolkit 4 version.
It's Work.
(3,598 Views)
