Problem in configuring and initializing FPGA
Hey, I have a Problem in initializing my FPGA, any suggestions?
Attached the real time and intializing VI
Message 1 of 15
(4,392 Views)
Hi ali,
which problem to you have?
Unfortunately you didn't attach the project file so we cannot examine the type of FPGA you are using. But I guess a FIFO size of 1M is rather large…
Message 2 of 15
(4,383 Views)
Hey,
Attached the Project file. Thanks
Message 3 of 15
(4,379 Views)
The Problem is I can Interface the Real-Time with the Host PC inorder to Display the evaluated data
Message 4 of 15
(4,376 Views)
Hi ali,
What is the problem when you can interface the RT target?
Message 5 of 15
(4,372 Views)
I'm sorry, it was a typo. I can not interface**
No values displayed(image attached)
Message 6 of 15
(4,367 Views)
Image attached for the FPGA-SENT Logger with CGS Modul V02.
It is displaying the data but not on host Pc
Message 7 of 15
(4,361 Views)
Hi ali,
How is that "pc" related to the RT and FPGA target?
(I didn't knew about the "Mobility" branch of 1stSensor. Glad to learn about them.)
Message 8 of 15
(4,352 Views)
Hi Gerd,
Thank you for your Kind words.
I have attached the Project above, you can see it in the Host_Main Vi. Can you suggest something so that so that I can see the evaluated data in the Host_Main aswell? It's being displayed correctly in the FPGA.main.  Any help would be greatly appreciated. Thanks
Message 9 of 15
(4,326 Views)
Hi ali,
The VI is no project file. Such files use a suffix of ".lvproj"…
LabVIEW comes with a huge library of example VIs and projects.
And there are examples showing how to transfer data between host PC <-> RT target <-> FPGA!
Message 10 of 15
(4,323 Views)
