Problem in getting accurate measurement using NI 9227
Grounded the shield of all four Lapp cables to one of the sensor's ground.
Message 11 of 23
(2,008 Views)
Grounding a cable shield will reduce externally induced noise, but that is not the same as a ground-referenced signal, in which the current signal analog input negative / common end is tied down.  Refer to the wiring diagram in the Operating Instructions and Specifications manual for the NI 9227.  It is possible that your problem is the result of common mode voltage differences between channels.
Message 12 of 23
(2,005 Views)
Thanks for your input.
I will try grounding Al- of all four ports.
Message 13 of 23
(2,002 Views)
I could not solve it yet.
I even tried grounding all the four AI- to ground of one sensor, but the output is still the same. Sometimes I get correct values from 3channels and sometimes I am not getting it whether I ground them or not. One of the channel always is providing 0.15mA difference. Even other channels provide 0.1mA difference.
I couldn't figure out what is the mistake I am doing.
Message 14 of 23
(1,983 Views)
Please provide a schematic of all your cable connections...
Greetings from Germany
Henrik
LV since v3.1
Message 15 of 23
(1,973 Views)
Please find the attached schematic below
Message 16 of 23
(1,965 Views)
Powersupply?
Henrik
LV since v3.1
Message 17 of 23
(1,959 Views)
Power for the CDAQ chasis and the devices which produces (D1-D4)4mA-20mA is provided(230V 50Hz). I forgot to mention them. Sorry.
Message 18 of 23
(1,953 Views)
No problem just include them in the schematic as found (and not as remembered 😉 :D)
Henrik
LV since v3.1
Message 19 of 23
(1,942 Views)
Have you tried using the shipping example to see if the readings are consistent?
Example Finder / Hardware Input and Output / DAQmx / Analog Input / Current - Continuous Input.vi
Message 20 of 23
(1,937 Views)
