Problem in scroll bar
Hi!
I am using Labview 5.0.In my application front panel contains a table
with vertical scroll bar.In the edit mode the scroll bar works.but in
the run mode I am unable to move the scroll bar of the table.In the
table having dynamic data display.
I am greate ful to you if give me the sollution
(3,000 Views)
Venki,
In the edit mode, you can edit the table and choose to display or not the scrollbars. This operation is not allowed in the run-time mode from the front panel.
However, you can use the property nodes. Right click on the table terminal on the block diagram and select Create>>Property Node. Then browse to the Vert Scrollbar and Horiz Scrollbar. Change them to Write, and wire a Boolean constant or control.
Zvezdana S.
(3,000 Views)
