Problem installing LabView 8.2 on Kubuntu
Trying to install LabView 8.2 on Kubuntu (7.04) here. The following is my install session :
Preparing for installation...
C runtime library (glibc) version: 2.5.
Please indicate whether you would like to install the following components:
labview82-rte: LabVIEW Run-Time Engine
[Ynasq?] Y
labview-rte-aal: LabVIEW Run-Time Advanced Analysis Support
[Ynasq?] Y
labview82-core: LabVIEW Application and VI Library
[Ynasq?] Y
labview82-examples: LabVIEW VI Examples
[Ynasq?] Y
labview82-help: LabVIEW On-line Reference Manual
[Ynasq?] Y
labview82-ref: LabVIEW Manuals in Adobe Acrobat (.pdf) format
[Ynasq?] Y
labview82-vxi: LabVIEW NI-VXI Support
[Ynasq?] Y
labview82-desktop: LabVIEW KDE and GNOME desktop support
[Ynasq?] Y
labview82-appbuild: LabVIEW Run-Time Application Builder
[Ynasq?] Y
labview82-pro: LabVIEW Professional Developers Tools
[Ynasq?] Y
Auto-selecting dependency niwebpipeline20_dep-2.0-5.i586.rpm
The following components will be installed using cpio:
labview82-rte-8.2-1.i386.rpm  44880 kB
labview-rte-aal-1.1-1.i386.rpm  20607 kB
labview82-core-8.2-1.i386.rpm  408746 kB
labview82-examples-8.2-1.i386.rpm  40245 kB
labview82-help-8.2-1.i386.rpm  65388 kB
labview82-ref-8.2-1.i386.rpm  3201 kB
labview82-vxi-8.2-1.i386.rpm  4482 kB
labview82-desktop-8.2-1.i386.rpm  61 kB
labview82-appbuild-8.2-1.i386.rpm  62328 kB
labview82-pro-8.2-1.i386.rpm  8884 kB
niwebpipeline20_dep-2.0-5.i586.rpm  5432 kB
Total space required: 664254 kB
Space available:      13797164 kB
Proceed? [Ynq] Y
Installing...
sort: Warning: "+number" syntax is deprecated, please use "-k number"
Installing NI Example Finder...
Would you like to install the LabVIEW web browser plugin? [Ynq] Y
Checking for Mozilla/Firefox/Netscape 6+ installation...
Copying plugin to /usr/lib/firefox/plugins
Copying plugin to /usr/lib/mozilla/plugins
Copying plugin to /usr/lib/mozilla-firefox/plugins
Copying plugin to /usr/lib/mozilla-snapshot/plugins
Copying plugin to /usr/share/firefox/chrome/classic/skin/classic/mozapps/plugins
Copying plugin to /usr/share/firefox/chrome/en-US/locale/en-US/mozapps/plugins
Copying plugin to /usr/share/firefox/chrome/toolkit/content/mozapps/plugins
LabVIEW package installation complete.
LabVIEW installation complete.
Beginning hardware driver installation.
Depending on your system configuration, some drivers may require you to reboot
after installation before you can access the driver.
Would you like to install NI-VISA (4.0) for GNU/Linux? [Ynq] Y
trap: 1821: SIGINT: bad trap
Would you like to install NI-GPIB (NI-488.2 2.5.1) for GNU/Linux? [Ynq] Y
trap: 673: SIGINT: bad trap
View the LabVIEW 8.2 Upgrade Notes now? [Yn] Y
Sorry, xpdf, ggv, kpdf or Adobe Acrobat Reader must be installed to view PDF files.
Installation complete.
What is the meaning of the trap messages above where it tries to install NI-VISA and NI-GPIB drivers ?
Yes, I know Kubuntu, like all popular and widely used deb based distros, is not officially supported.
I have confirmed that I am running a 8K stacks kernel (2.6.20-16-generic). I have lsb-rpm and libdb1-compat packages installed and I did symlink /usr/lib/rpm/rpmq to /bin/rpmq. There was no rpmq (only rpmquery) in /usr/bin.
(3,999 Views)
I would try "man trap".  Whatevery program you are running to install labview might be a shell script.  If it is, poke around in there and try and see whats going on.  Wish I could help more.
(3,982 Views)
Oh and please post back if you do figure it out.
--Patrick
(3,954 Views)
