Problem installing PID Control Toolset
I installed the PID Control Toolset and received a message stating that:
"Error 1401. Could not create key. S..............................\Software\Microsoft. Verify that you have sufficient access to that key, or contact your support personel."
Do you know what I should do?
Thank you
(3,655 Views)
Please don't embed a picture in an Excel document.  Just post the picture as an attachment of a .png file.
When you are installing, do you have admin rights to the PC?
(3,644 Views)
Thanks for your reply, Ravens.
Sorry about the excel file but I just can printscreen & paste.
The PC is on a network and I believe the admin had already set my account as the administrative one. Normally, my account has no right to install or uninstall. (Is there more than one type of admin account, if it's the case?)
I have been installing Labview 7, Daqmx, report generation toolkit without any problems.
(3,640 Views)
Cut and paste into Microsoft Paint.  Then do a save as .png.
There are other accounts such as power user which has some rights, but not as many as an admin.  I've never been anything but an admin on my machines.  I don't know if you were under some restricted mode, whether some things would install okay and the PID toolkit would act differently.
Let's see if anyone else has any ideas.
(3,626 Views)
Accepted by topic author 421939126
That error clearly indicates a Windows permissions error. It sounds like your admin gave you limited administrative rights (such as a member of the Power Users group), so your best bet is to show the error message to them and either ask that they install the software, or to give you adequate rights to install it.
EDIT: RF posted response at the same time...
(3,622 Views)
Thanks heaps guys,
I'll get back to IT.
Cheers.
(3,603 Views)
