Problem: number with decimal
Hi everyone,
I have a problem with the decimals in Labview.
When I was running the project I saw a problem.
The number was without a decimal.
To solve this problem, I made the conversion as shown in the attachment.
The problem seems to be solved when opening the screen for the first time.
But when I close the screen and open it again, the decimal is gone.
This is, because the variable is loaded into the variable manager, I think.
But when I'm watching the variabele in the variable manager, I see a number with decimal.
But not in the screen.
Can someone help me to solve this problem.
I don't know what to do anymore.
Kenny
(3,811 Views)
R-click the control/indicator and check the "Display Format" properties.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,795 Views)
I allready did these settings.
All the settings are ok.
I did make different settings in the property window but it didn't help.
It's very strange, and because of that I am posting this problem.
Kenny
(3,792 Views)
Can you post your code and let us know which version of LabVIEW that you are using?
(3,777 Views)
This is the VI I am talking about.
It's not possible for you to run the VI in this way.
Because it has to be linked to an OPC server.
But in this way you can see what the settings are and maybe can help me.
Kenny
(3,750 Views)
I am using Labview 8.2.1
(3,749 Views)
Is it the control / indicator for the airflow (cfm)?
If so, you are hiding the trailing zeros.
(3,715 Views)
