Problem of importing Sub VI
I'm using the code attached in the following link successfully:
https://forums.ni.com/t5/Example-Code/GPS-gather/ta-p/3494576
However, it stuck when using as Sub VI in my program. Any suggestions???
(2,098 Views)
Accepted by topic author Omda2022
Hi Omda,
You can copy it's funcitonality, but you need to remove all UI handling stuff including all outer loops…
(2,090 Views)
This vi is structured as a main vi, not a subvi. If you want to show its UI in your program, however, you need to edit its properties, Window Appearance, Customize..., the set the following:
also preferably change the Behaviour to Modal.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,079 Views)
For illustration, I need to load some output variable from the GPS.VI (sub VI attached in the previous link) to my VI, not the front panel itself.
Kindly, download my VI attached below for more declaration.
(2,066 Views)
I cannot open your vi because currently I have only LabVIEW 2017 on my machine.
If you want to use the vi functionalities, as per GerdW's advice, you need to copy part of the example code (which is not top quality I fear) in your own vi. Especially the subvi's, as the main vi structure is quite bad in my opinion.
Paolo
(2,040 Views)
Great Thanks, Mr. , and Mr. pincpanter for your cooperation.
Best Regards 🙂
(2,019 Views)
