Problem of waveform.
Hi all,
       I'm trying to generate a signal by reading data from Excel. But the waveform comes from Excel is static waveform. Is there any method to make the waveform move. I mean... make it as a signal just like it comes from a signal generation.
Thank you very much,
Laffer
(2,811 Views)
Hi Larry,
well, an Excel file is usually something "static" when you use it as data source…
How will you "animate" that file?
(2,806 Views)
