Problem on Normalized Frequency to original analog frequency
I'm having a problem regarding normalized frequency.
The Sine wave .vi, says that the input to the frequency  must be a normalized frequency. What I did is tha I divide my frequency to the number of samples.
However, when I attached Tone Measurements to output signal of the sine wave, I'm not having a frequency of what i set.
In my example my input frequency is 60 Hz however what was detected by the tone measurement was the normalized frequency which is 0.06.
How do I modify this VI, in order that i will have a frequency in 60 hZ,
(4,340 Views)
Anyone please help?
(4,318 Views)
The problem with trying to calculate a frequency is that you need a time element.  You don't have a time element.  So I'm thinking 1 sample/second is used.
Try using the Sine Wave.vi (it is in the Signal Processing->Waveform Generation palette).  With that function, you need to supply the sample rate and the actual frequecy that you want.
(4,311 Views)
You have any other ideas regrading this matter?
(4,282 Views)
What was wrong with using the waveform generating function I suggested?
(4,268 Views)
You already know how to add dt to a waveform so why aren't you doing it now?
http://forums.ni.com/t5/image/serverpage/image-id/161250i0CB6D7B4414D7F3D/image-size/original?v=mpbl...
(4,256 Views)
