Problem reading serial port.
Hi everybody. I am trying to control a video measurement equipment
through serial port. The answers from that equipment are variable
length strings (from tenths of bytes to thousands)and I have no problem
at all when I run the program step by step or I have all vi´s used
during I/O operations opened at the same time. However, if I try to run
it just opening the front panels programatically, no serial reading is
got.
I first thought it could be a timing problem (in fact I am using some
delay when I read serial port)so I added some more delays, but anything
changed at all so, perhaps it is a problem concerning to the way all
the panels are opened and closed. If any of you has ever experienced
this kind of problems y would apprec
iate very much your help. Thanks in
advance to all.
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,315 Views)
dou you have the serpdrv
in the same directory then the .EXE file ?
mostly, it helps
Jean-Luc
a écrit dans le message :
8fj870$9dl$1@nnrp1.deja.com...
> got.
> this kind of problems y would appreciate very much your help. Thanks in
> advance to all.
> Before you buy.
(3,315 Views)
Hi!
You should try the VISA functions to communicate with your device. In most
cases, it works better then the usual serial VI's.
Vlad
(3,315 Views)
