Problem reading txt file
Hi
I have a shell cluster where I type different data for my file. Then I save this to txt file. The problem is when I want to open the file and use the data for the same shell cluster, which is now an indicator. Can someone help me with this??
(3,179 Views)
You need to replace the Initialize Array function (which creates an empty array the way you have it connected) with the Spreadsheet String to Array function. Wire a Line Feed constant to the delimiter input and "%s" to the format string input.
Lynn
(3,174 Views)
Thank you on your fast reply. How do I connect the array terminal to the shell cluster indicator??
I am new at this..
Boris
(3,164 Views)
Hi Boris,
see the attached example. It is better if you insert your input data into the save event, because you then save the newest values.
Mike
(3,150 Views)
Thank you Mike  !!!!
Boris
(3,147 Views)
