Problem reading/writing disk files with standalone application
Hi all
I've developed a VI which works fine when run through IDE. It is able to read / write the disk files just fine. However, when i build it as a standalone EXE, its working fine except being able to read / write the disk files. Please help in this regard, and suggest where the problem is and how can it be solved.
I'm using Windows XP and LabVIEW 6.0
Thanks a lot
(3,684 Views)
A common mistake that people make when first creating an exe is that they don't take into account that paths are slightly different afterward. If you use the Current VI's Path function in development mode, the path might be something like c:\folder\example.vi. When built, the path will be c:\folder\app.exe\example.vi. So, to get to the folder, you have to do an extra strip path. You should modify your VI to use the appplication property App.Kind. If it returns Run Time System, do the extra strip path with a case statement.
(3,674 Views)
Probably related to this other question the user posted.
(3,504 Views)
What sort of error do you get?
You ARE monitoring the ERROR output of the file functions, aren't you?
Steve Bird
Culverson.com
LinkedIn
(3,486 Views)
Are you asking it related to this question? It has already been solved. Pls see the above post.
(3,476 Views)
